Mobile weapons ala James Hawke
Kaizer
Inspired by James' fake character profile, I decided I'd post up a sample of what NOT to do when you can use a custom mobile weapon.  I hope James doesn't mind me using John A. Cliche Extravagant for this little spoof.
General and Technical Data
Model number: ABC-DEFG123
Code name: Strike Freedom Extravagant
Unit type: Ultra-super secret production doomsday mobile suit
Manufacturer: John A. Cliche Extravagant
Operator: John A. Cliche Extravagant
First deployment: CE 80
Capacity: Single Seater in Panoramic cockpit in head
Height: 44.5 meters
Weight: 24.5 metric tons
Construction: Ultra-light Gundanium Alloy
Power plant: Micro-fusion engine, output estimated at 5 000 000 000 KW
Equipment and design features: Sensors, Thrusters, Wings of Light, Mirage Colloid, Phase Shift Armor, Geschemeidig Panzer, Zero system, T-link System, Hardpoints to attach to METEOR, N-Jammer Canceller, Extravagant custom-OS, living quarters in torso
Fixed armaments:
1x Lohrengrin positron cannon, mounted in torso
8x DRAGOON (Disconnected Rapid Armament Group Overlay Operations Network), using 8x standard bits
(2x beam gun), stored in wings of suit.
4x "Super Lacerta" beam saber, stored in arms and legs of mobile suit
4x "Igellstellung" 75mm CIWS, fire-linked, mounted in head
2x "Valiant Mk.II" Linear cannons, hip mounted, fold out in use
Optional hand armaments:
2x Buster Rifle, hand carried in use, can combine to form a Double-Buster rifle
1x Nuclear Missile Launcher, hand carried in use
Technical and Historical Notes
After destroying his Ultimate Gundam Infinite Freedom in an action movie, John took some time off to design a new mobile suit; the Strike Freedom Extravagant.  Its power is unmatched thanks to its fusion engine, and no mobile suit has been able to match its speed, which is close to the speed of light.  Nobody but John can pilot it because of its complicated OS, which John personally designed for use with this mobile suit.  It also has a living room built into its torso, so John never has to leave his suit unless he wants to.
