Point System
winders
  ActionPoints
  Melee
  Melee weapon hit against shield
  100
  Melee weapon hit against non-critical component
  200
  Punch against non-shield part
  150
  Kick against non-shield part
  150
  Shield ram
  100
  Ranged
  Machine Gun against non-shield
  # of bullet-hits x 100
  Beam Gun against non-shield
  200
  Plasma Gun against non-shield
  400
  Rail Gun against non-shield
  400
  Vulcan cannons against non-shield
  50
  Missiles against non-shield
  # of missile-hits x 25
  Grenade/Grenade Launcher against shield
  150
  Grenade/Grenade Launcher against non-shield
  300
  Other
  Taking off a limb
  500
  Taking off a head
  750
  Disarming an opponent
  250
  Destroying a weapon*
  500
  Using terrain as a weapon
  Case-by-case
  Running out of energy (10% or less, once)
  -1000
  Combos
  Base combo formula
  # of hits x 75 + Value of each hit**
*If a part of the body say a head with weapons mounted in it; in this case vulcans is blown up or taken off, then the destroying a weapon is not counted.
**Example: five hits with machine gun against non shield, two hits with beam sabre against non-shield and critical component, taking the head.
7 x 75 + (5 x 100) + 200 + 750 = 1975 points
Referees are to keep count of points scored during battle with a running tally after every combat round. High scores consist of the top 10 scores in 1v1s. On the scoreboard the team name of the player is also listed, the name that appears is the character used in the coliseum. Battles that are rigged to earn points will be D/Qed by referees and points earned will not be recorded.
[align=center]© 2005-2006 Advent Destiny.
Please refer to here for more copyright information.[/align]
  • 10 months later...
Note that the Point system is not a requirement for matches, and is merely an optional choice.  Should a player wish to use the point system in a match, they must be sure to note it when they first post their initial rules of engagement.  As with all rules of engagement, all participants must agree to the rules before the match begins.
